PIX 515E DMZ config
Mar 9th, 2007
If the PIX has it's inside interface on it's own subnet, uplinked to 4503 switch (10.10.10.0), and the workstations and servers are on different subnets (10.10.20.0, 10.10.30.0), and using the switch as their default gateway, how do you set up the NATing to allow access to servers in the DMZ from the inside Interface?
Do I set up seperate NAT
Overall Rating: 5 (4 ratings)
hoogen_82 Sat, 03/10/2007 - 02:46
  • Silver, 250 points or more
First thing is getting your route inside statements right.
route inside 10.10.20.0 255.255.255.0 10.10.10.1
route inside 10.10.30.0 255.255.255.0 10.10.10.1
The above statements are assuiming that your switch ip is 10.10.10.1.
Then i believe you mist have already had nat (inside) 1 10.10.20.0 255.255.255.0 and nat (inside) 1 10.10.30.0 255.255.255.0 statements
global(dmz) 1 interface or else type the address you want it to translate it to.
Thats all.
Hoogen
richmorrow624 Sat, 03/10/2007 - 04:40
I have all of this and I still am unable to ping the DMZ interface, there is no host machine on the DMZ at the moment.
Shouldn't I be able to ping the DMZ interface though?
kaachary Sat, 03/10/2007 - 04:46
  • Cisco Employee,
Try this :
static (inside,dmz) 10.10.20.0 10.10.20.0
static (inside,dmz) 10.10.30.0 10.10.30.0
route inside 10.10.0.0 255.255.0.0
That should do it.
(Please rate if helped)
-Kanishka
