Unity JRE tzupdate error and fix - FYI
Mar 9th, 2007
  • Silver, 250 points or more
FYI, Just in case anyone applies the JRE Tzupdate and gets errors like below. You may try to copy the tzupdater files to a folder off the root, like c:\dst instead of keeping them under the unity_dst_updates folder or where ever you extracted them to.
Did not work:
E:\DSTUpdate\Unity_DST_Patches\JRE_time_zone_update>e:\CommServer\cscoserv\Ja
va2
SDK\jre\bin\java -jar tzupdater.jar -u -v -bc
Exception in thread "main" java.util.zip.ZipException: The system
cannot find th
e file specified
at java.util.zip.ZipFile.open(Native Method)
at java.util.zip.ZipFile.<init>(ZipFile.java:112)
at java.util.jar.JarFile.<init>(JarFile.java:117)
at java.util.jar.JarFile.<init>(JarFile.java:55)
When it worked:
C:\dst>E:\CommServer\cscoserv\Java2SDK\jre\bin\java -jar tzupdater.jar -u -v
-bc
java.home: E:\CommServer\cscoserv\Java2SDK\jre
java.vendor: Sun Microsystems Inc.
java.version: 1.4.0_01
JRE time zone data version: tzdata2001d
Embedded time zone data version: tzdata2006p
Extracting files... done.
Making changes for JDK 1.1 compatibiltiy... done.
Renaming directories... done.
Validating the new time zone data... done.
Time zone data update is complete.
C:\dst>
