Cisco Filesystem
Mar 9th, 2007
Hello Everyone!
I've got a Cisco 200 Micro Webserver (mweb200) with a damaged scsi harddrive.
I've ordered a new one now , but i dont know how to format it when i will put it in the micro webserver. The documentation clearly says "The Micro Webserver 200 cannot format new SCSI hard drives. However, it can read the hard drive directly from a Windows 95 or Windows NT system." I think it uses the same filesystems as the Cisco Content Router 4400. Does anyone know how to format these disks ? Also , what do cisco mean with "However, it can read the hard drive directly from a Windows 95 or Windows NT system." ?
inch Sat, 03/10/2007 - 19:37
  • Bronze, 100 points or more
Howdy,
Going by what it says... it sounds like it would be a FAT filesystem if it could be read by windows 95... :)
ewf_cirda Sun, 03/11/2007 - 01:14
Yeah , but this filesystem is called uvfat , and i dont know where to get it...
mark.duffy Sun, 03/11/2007 - 14:00
Not sure if you have the answer but this may help?
http://linux.voyager.hr/umsdos/
The format of the disk is a linux version of FAT which knowing Cisco and its love for Linux in most of the CE type devices. Have a look and see if partition magic supports it as a format?
Hope that helps,
Mark
ewf_cirda Sun, 03/11/2007 - 15:26
I've checked the list of PartitionMagic and it doesnt support uvfat , only FAT,FAT32(vfat),NTFS,EXT2, and EXT3. Also , i dont know if i should create a regular partition table on the disk , or create the filesystem directly on the disk, could anyone put me in the right direction ? I think the answer would be on the Cisco Content Router 4400 , because it uses uvfat.
