CME 4 - Cannot call Sip Handsets from SCCP Handsets
Answered Question
Mar 10th, 2007
I'm running cme 4 with several sccp 7960s on extention range 1400 and all is fine. I'm now trying to add a sip handset (non-cisco) - although I can get it to register and it's able to call sccp phones(showing correct extention number and name) - sccp phones cannot call sip phone - they get engaged tone.
Relevant Config Below:
voice register global
mode cme
source-address 192.168.4.253 port 5600
max-dn 3
max-pool 3
dialplan-pattern 1 14.. extension-length 4
voice register dn 1
number 1402
voice register pool 1
id mac 000B.8203.E7C6
number 1 dn 1
username 1402 password 1402
codec g711ulaw
any ideas?
Correct Answer by Paolo Bevilacqua about 9 years 10 months ago
Looks like an ephone-dn is using the same number, it dynamically creates dial-peer 20003, that has precedence over 40001 because the $ at the end (larger number of matched digits).
Overall Rating: 5 (1 ratings)
Paolo Bevilacqua Sat, 03/10/2007 - 09:42
Collect "debug ccsip message" with "term mon" and to see what error the phone is sending.
anthonyfear Sat, 03/10/2007 - 09:55
Tried your suggestion - can see plenty of debug info when placing call from sip handset to sccp. But when placing call from SCCP to SIP there is no debug info at all.
anthonyfear Sat, 03/10/2007 - 10:06
C1751V#show voice register pool 1
Pool Tag 1
Config:
Mac address is 000B.8203.E7C6
Number list 1 : DN 1
Proxy Ip address is 0.0.0.0
DTMF Relay is disabled
Call Waiting is enabled
DnD is disabled
keep-conference is enabled
Dialpeers created:
dial-peer voice 40001 voip
destination-pattern 1402
session target ipv4:192.168.4.29:5060
session protocol sipv2
codec g711ulaw bytes 160
after-hours-exempt FALSE
Statistics:
Active registrations : 1
Total Registration Statistics
Registration requests : 1
Registration success : 1
Registration failed : 0
unRegister requests : 0
unRegister success : 0
unRegister failed : 0
Correct Answer
Paolo Bevilacqua Sat, 03/10/2007 - 10:16
