Using "wmt multicast station-configuration" command
Mar 10th, 2007
I would like to use the "wmt multicast station-configuration name D-class-IP" command, but then instead of having the clients connect to the content engine's IP, I would like them to connect to the D-class-IP. Is this possible? Would it require the content engine's default gateway to do an "ip igmp join-group" for the D-class IP?
IGMP / PIM-DenseMode is enabled on the routers.
The reason I would like to do it this way, btw, is that I would like to push this config out to 70 content engines and then give out one URL to all potential clients pointing to the one D-class IP.
Thank you.
sadbulali Thu, 03/15/2007 - 15:08
  • Bronze, 100 points or more
Use the wmt multicast {schedule-start name minute hour day month | station-configuration name dest_addr dest_port media_source [play-forever]} command to enable WMT multicasting for the unicast-in multicast-out and multicast-in multicast-out scenarios on the Content Engine. The schedule-start name minute hour day month option creates a scheduling option to allow the Content Engine to start a multicast at a specified time. This option only works if you have configured a multicast station first, using the wmt multicast station-configuration command.
Refer this link:
http://www.cisco.com/en/US/products/sw/conntsw/ps491/products_configuration_guide_chapter09186a0080131e6e.html#1082433
