Cisco 7970G SIP Config Issues - Please Help
Mar 10th, 2007
Hi, I have a 7970G and I can?t seem to get it to connect to my VOIP Via Talk. The registration credentials are all perfect. I'm also running SIP70.8-0-2SR1S which does not have the random high udp port request security feature that the newer versions do. I believe my config file is bloated and has unnecessary of conflicting tags that are causing the phone to not be able to register. Can anyone confirm this and possibly show/tell me what to remove/add.
Any help would be greatly appreciated.
Here is my config file:
Paolo Bevilacqua Sun, 03/11/2007 - 09:59
It's a bit hard to tell what could be the problem by looking at the config only. Can you take an ethernet trace to see the SIP messages and why it is failing ?
