03-11-2007 08:54 AM
hi all,
i am trying to configure my internet connectivity my designe is :
ISA is connected to core switch (4003) having 1 interface. ip address is for the nic card is vlan ip address.
pix inside interfacce is in same vlan that is ISA port, so i can ping from pix to ISA and ISA to pix.
pix outside interface is configured in Layer-2 vlan i hv created seperate Layer-2 VLAN for this diag. and having internet pool ip address i.e. valid ip address
internet router faast ethernet is connected to my core and this port is also in layer 2 vlan same like pix outside interface. and ip address is from internet pool i.e. valid ip.
internet router serial is connected to my isp.
but still i am not able to surf from my vlan's.
please give me suggestions.
Thanks & Regards,
Ciscobuddy
03-11-2007 08:57 AM
hi,
i have natted ISA ip on my pix ; static inside outside.
Thanks & regards,
Ciscobuddy
03-11-2007 05:04 PM
You are not able to surf the vlan frm where ?
From Internet..or from inside ?
Please clarify.
-Kanishka
03-12-2007 07:47 AM
Hi Buddy,
make sure that you had given a default route the internet "route outside 0.0.0.0 0.0.0.0 x.x.x.x"
Note: Where "outside" is the interface which is pointing towards the internet.
