No DSP resources available to configure pri-group on controller T1
Mar 11th, 2007
i have this error and for resolve i dont have card type command
"You can potentially encounter the following symptoms or error messages when configuring IP Communications High-Density Digital Voice/Fax Network Module:
% No DSP resources available to configure pri-group on controller T1
%XCCTSP_VOICE-3-NOSDB: No signaling data block is available to build the voice interface(1/0:23) or DSP may not be present
The above errors can be resolved by doing DSP Resource Sharing or adding more digital signal processors (DSPs). For more information refer to the DSP Calculator tool.
Unable to see PRI ports ( controller T1 or E1 ) in the router configuration for an NM-HDV2-2T1/E1 network module. To resolve this issue, you need to enable the card type by issuing the following command: card type {t1 | e1} slot [bay]"
Router#sh ver
IOS (tm) 3600 Software (C3640-JS-M), Version 12.2(15)T17, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Fri 12-Aug-05 13:32 by kehsiao
Image text-base: 0x60008950, data-base: 0x61E30000
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
ROM: 3600 Software (C3640-JS-M), Version 12.2(15)T17, RELEASE SOFTWARE (fc1)
Router uptime is 2 weeks, 3 hours, 33 minutes
System restarted at 15:19:08 IRST Sun Feb 25 2007
System image file is "flash:c3640-js-mz.122-15.T17.bin"
cisco 3640 (R4700) processor (revision 0x00) with 125952K/5120K bytes of memory.
Processor board ID 19739098
R4700 CPU at 100Mhz, Implementation 33, Rev 1.0
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
Primary Rate ISDN software, Version 1.1.
2 Ethernet/IEEE 802.3 interface(s)
32 Serial network interface(s)
2 Channelized E1/PRI port(s)
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
Overall Rating: 5 (1 ratings)
reza.behroozi Mon, 03/12/2007 - 05:20
thanks for reply
Router#sh diag
Slot 0:
Combo 2E, 2W Port adapter, 4 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware revision 1.2 Board revision E0
Serial number 24387728 Part number 800-01171-05
FRU Part Number: NM-2E2W=
Test history 0x0 RMA number 00-00-00
EEPROM format version 1
EEPROM contents (hex):
0x20: 01 1E 01 02 01 74 20 90 50 04 93 05 00 00 00 00
0x30: 70 00 00 00 01 01 27 17 FF FF FF FF FF FF FF FF
WIC Slot 0:
Serial 1T WAN daughter card
Hardware revision 1.0 Board revision J0
Serial number 19862264 Part number 800-01514-01
Connector type Wan Module
0x20: 01 02 01 00 01 2F 12 F8 50 05 EA 01 00 00 00 00
0x30: 98 00 00 00 00 06 18 01 FF FF FF FF FF FF FF FF
Slot 3:
High Density Voice Port adapter
Hardware Revision : 1.1
Top Assy. Part Number : 800-03567-01
Board Revision : G0
Deviation Number : 0-0
Fab Version : 02
PCB Serial Number : JAB061308A3
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
EEPROM format version 4
0x00: 04 FF 40 00 CC 41 01 01 C0 46 03 20 00 0D EF 01
0x10: 42 47 30 80 00 00 00 00 02 02 C1 8B 4A 41 42 30
0x20: 36 31 33 30 38 41 33 03 00 81 00 00 00 00 04 00
0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
WIC Slot 0:
E1 (2 Port) Multi-Flex Trunk WAN Daughter Card
Hardware revision 1.0 Board revision B0
Serial number 29238127 Part number 800-04479-03
Connector type PCI
0x20: 01 23 01 00 01 BE 23 6F 50 11 7F 03 00 00 00 00
0x30: 58 00 00 00 02 09 13 00 FF FF FF FF FF FF FF FF
HDV firmware: Compiled Wed 16-Jan-02 20:43 by pkonda
HDV memory size 524280 heap free 169549
pacameron Thu, 03/22/2007 - 22:45
  • Silver, 250 points or more
Your NM-HDV card does not have any PVDM-12 DSP modules installed on it, so you do not have the DSP resources to create the voice ports.
It will need at least 3 PVDM-12 modules to support a single 30 channel E1 interface.
