Site to Site problems
Mar 11th, 2007
I have two pix firewalls a 515E and a 506E there is another router that I have no access to. I have tried using the VPN wizard to connect the two site and they will not connect. I have had a connection to the other router and connection to a vigor router.
Here is the config from both routers
acomiskey Mon, 03/12/2007 - 07:19
You don't have nat exemption on sevenoaks pix.
nat (inside) 0 access-list no-nat
access-list no-nat permit ip
Kamal Malhotra Mon, 03/12/2007 - 07:44
However needless to say, but the commands go in the reverse order i.e. you configure teh access-list first and then the nat command.
Please rate if it helps.
bartollo1 Thu, 03/15/2007 - 05:04
I have wiped the config and I am trying this on a different box here are the configurations.
I cannot add the line
The tunnels do not even try to establish. Has anyone got a pix to pix work using the wizards.
Is there any documentation for 6.3(5) for site to site pix.
acomiskey Thu, 03/15/2007 - 06:29
Just a quick look, it seems you are trying to add "no-nat" when your acl is "nonat".
Try it without the "-". Just looked more closely, you already have inside_nat0_outbound, you do not need to add another nat 0.
bartollo1 Thu, 03/15/2007 - 07:22
This was created by the wizard.
I have tried many thing before accessing the site. has anyone got the configuration files that work on two pix's so I can replace them with my ip adress. It would be a hell of a lot easier to do this than just addeding a line at a time.
sorry for being a bit blunt.
