Does a Cisco 2501 Router support InterVLAN Routing?
Danilo Dy Sun, 03/11/2007 - 19:55
  • Blue, 1500 points or more
They should both support 802.1Q and ISL
For example, 2912XL-EN port FastEthernet0/12 is connected to 2501 port FastEthernet0. Try the following commands
For 802.1Q
1. 2501 Router
interface fastethernet0
no ip address
full-duplex
speed 100
interface fastethernet0.1
encapsulation 802.1Q
ip address 192.16.0.1 255.255.255.0
2. 2912XL-EN Switch
interface fastethernet0/12
switchport mode trunk
full-duplex
speed 100
For ISL
1. 2501 Router
no ip address
full-duplex
speed 100
encapsulation ISL
2. 2912XL-EN Switch
switchport trunk encapsulation isl
full-duplex
speed 100
devang_etcom Sun, 03/11/2007 - 20:05
  • Gold, 750 points or more
it is recommended to use 100Mbps FastEthernet for the InterVlan Routing...
and most probably 2501 router is not supporting the Intervlan routing... not sure... just check...
fire the following commands:
router#conf t
#interface ethernet 0
#encapsulation ?
if you find any dot1q or ISL option then that router is supporting intervlan routing... if you dont find any option like dot1q and ISL then you can not configure the Intervlan routing...
regards
Devang
Richard Burts Sun, 03/11/2007 - 21:19
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
The chip set used in the 2500 series routers (a very old part of the product line) do not support any kind of trunking.
Rick
