E1 configuration problem
Mar 11th, 2007
  • Community Spotlight Award,
    Spanish Member's Choice: May 2016
Hello I am trying to configure a WAN link using a E1 MFT VWIC2 on a router 3725 when I try to configure the second E1 tyo establish a PPP Multilink I gethe following error message:
%Insufficient resources to create channel group
er-cumana1(config-controller)#
*Mar 9 19:40:56: No Free HDLC resources (0)
I tried to upgrade from 12.2 to 12.3 version cause I only have 32 Mb on flash and 128 on RAM. Not enough to get a 12.4 IP VOICE version.
What do you suggest to solve this issues??
Is there a version that I can use to get both e1 up?
Thanks a lot for your time
Danilo Dy Sun, 03/11/2007 - 19:46
  • Blue, 1500 points or more
When independent clocking is configured, the controller will support only one channel group. If more than one channel group is configured, the following error message occurs "%Insufficient resources to create channel group"
Router(config-controller)# clock source {line [primary | hits] | internal} [independent]
or check this link for global command "network-clock-participate"
http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_command_reference_chapter09186a00800b350b.html#wp1001437
