What Cisco routers support more than basic traffic shaping? I cannot seem to determine, for sure, which models support class based and distributed class based traffic shaping.
Specifically, I am most interested in the 1800 series for my applications, with a v.35 interface, or based on your feedback a higher end unit comparable or superior to the Adtran Netvanta 3305 appliances I am using.
I am looking at replacing several Adtran appliances due to their lack of any form of traffic shaping support. The problem is simple but difficult at the same time because of a lack of traffic shaping support. The circuits are used for internal web browsing, external hosting (email, web, dns, etc), and also our VPN and latency sensitive voice traffic on two ethernet interfaces (eth0 for private, eth1 for public). The links are easily saturated by a user downloading a file from the internet, killing the ability to carry reliable voice across the links. I am looking at a drop in solution to directly replace my Netvanta 3305 VPN units using a serial nim - adding what is most heavily needed, traffic shaping support.
In addition, the voice is carried across a VPN tunnel. It is necessary to enable out-of-order packet processing to insure QOS in such a situation. Is this possible with a suggested Cisco appliance? I imagine it is.
It is unlikely that the appliances would be used in an environment in the short term with more than 3mbps worth of throughput, though in the next 6-12 months that could expand to 10mbps.
Thanks very much for your feedback.
