03-12-2007 02:36 AM - edited 03-05-2019 02:50 PM
I am using route-maps on a 3750 to forward traffic to a specific next-hop. I would like to use "set ip next-hop recursive a.b.c.d" as the next hop is not a local network.
However the feature navigator shows this as unsupported command on 3750's.
Can anyone confirm this as I am unable to try this command as the switch is in a live network?
Cheers
Richard
Solved! Go to Solution.
03-12-2007 09:39 PM
Hi Richard
I feel if its mentioned not supported in Feature Navigator i dont think you will be able to go with that command..
But did you try checking up the command reference guide of the ios installed in your box..
http://www.cisco.com/en/US/products/hw/switches/ps5023/prod_command_reference_list.html
regds
03-12-2007 09:39 PM
Hi Richard
regds
03-13-2007 02:06 AM
Many thanks for the guide. I had got round to checking and its not there.
Cheers
Richard
