vpn client but no internal or internet access
Mar 12th, 2007
  • Bronze, 100 points or more
hello,
i have configured the client vpn on pix 515E and the user can connect successfully but they don't get any internal access to any servers also cannot browse internet.
my config as following.
ip address outside 213.2.3.4 255.255.255.240
ip address inside 172.20.4.60 255.255.0.0
access-list nonat permit ip 172.20.0.0 255.255.0.0 192.168.1.0 255.255.255.0
access-list 120 permit ip 172.20.0.0 255.255.0.0 192.168.1.0 255.255.255.0
ip local pool vpnclient 192.168.1.1-192.168.1.2
route inside 192.168.1.0 255.255.255.0 172.20.4.1 1
sysopt connection permit-ipsec
crypto ipsec transform-set vpn esp-aes-256 esp-sha-hmac
crypto dynamic-map dynmap 30 set transform-set vpn
crypto map transam 1 ipsec-isakmp
crypto map transam interface outside
isakmp nat-traversal 20
isakmp policy 30 authentication pre-share
isakmp policy 30 encryption aes-256
isakmp policy 30 hash sha
isakmp policy 30 group 2
isakmp policy 30 lifetime 86400
vpngroup sec address-pool isnetvpn
vpngroup sec dns-server 172.20.1.10
vpngroup sec wins-server 172.20.1.10
vpngroup sec default-domain xyz.com
vpngroup sec split-tunnel 120
vpngroup sec idle-time 1800
vpngroup sec password ********
any help would be great
daviddtran Mon, 03/12/2007 - 05:06
I think you need this:
nat (inside) 0 access-list nonat
access-list split permit ip 192.168.1.0 255.255.255.254 any
vpngroup sec split-tunnel split
David
zulqurnain Mon, 03/12/2007 - 05:46
hello,
actually i already have nat (inside) 0 access-list nonat
i only forgot to paste in the post, secondly i tried with
but no luck, still the same.
acomiskey Mon, 03/12/2007 - 06:14
  • Green, 3000 points or more
What's this route for? That would include your vpn pool.
and shouldnt the split acl be
access-list split permit ip 172.20.0.0 255.255.0.0 192.168.1.0 255.255.255.0
zulqurnain Mon, 03/12/2007 - 06:49
the route is for the pix to know that it's local to it. actually it did'nt worked so i removed it
and yes the split is as what are have written but still no luck..
access-list split-vpn permit ip 172.20.0.0 255.255.0.0 192.168.1.0 255.255.255.0
i cannot understand the connection works fine and even on pix i see tunnel is created and both phases are completed in syslog .. still i can't access anything inside once connected must be something i am missing.
any help would be really apperciated
acomiskey Mon, 03/12/2007 - 07:00
Your vpn client pool name does not match what you have in your vpngroup
should be....
ip local pool isnetvpn 192.168.1.1-192.168.1.2
zulqurnain Mon, 03/12/2007 - 07:29
hello,
sorry that was the typo mistake while writing on the forum... that is what is should be. both are the same
acomiskey Mon, 03/12/2007 - 07:45
Could you just post config then?
acomiskey Tue, 03/13/2007 - 05:45
these are not correct...the source is wrong, should be your inside network which you would like to cross the tunnel.
access-list nonat permit ip 1.2.3.4255.255.0.0 192.168.1.0 255.255.255.0
access-list split-vpn permit ip 1.2.3.4255.255.0.0 192.168.1.0 255.255.255.0
