7914 expansion module configuration process
Mar 12th, 2007
I need to configure and operate in a 7914 expansion module with a 7960 phone.
Hardware is installed and working good (all lights are OK) but I can't configure it good because the 7914 screen doesn't show anything that I configure in speed dials.
Overall Rating: 1 (2 ratings)
alessandro.dona Mon, 03/12/2007 - 08:57
Have you configured your phone to support 7914 expansion module?
If you haven't go to the phone administartion page and fill the expansion module field 1 and select default 7914 then click update and then reset yoou device
