deploying IPCC
Mar 12th, 2007
Hello guys,
the company I work for is using CCM 4.0 which was upgraded from version 3.3. The IPCC software which comes in the package is version 3.3. Can i install the IPCC 3.3 with CCM 4.0? if not what options do I have to upgrade to a version compatible with CCM 4.0? we have a current contract with cisco. Thanks in advance
Overall Rating: 4 (2 ratings)
lpezj Mon, 03/12/2007 - 06:15
I think that you have to use IPCC Express version 3.5(X) or 4.0 with CallManager 4.0.
So, try to ask for an upgrade to Cisco of your IPCC Express.
Hope this helps,
Juan Luis
(Plaese, rate the helpful posts ;-))
