Citrix over VPN 3000
Mar 12th, 2007
i am configuring a VPN 3000 Concentrator, it's my first time!! By WebVPN I konw that it is possible to use Citrix applications through web interface of Citrix (webclient), but i would like to know if it's possible to do that with Program Neighborhood, without installing web interface.
Can anybody help me? Can i use Port Forwarding to do that?
Thanks in advance and best regards,
Luis
ggilbert Wed, 03/14/2007 - 08:46
  • Cisco Employee,
Luis,
I do not think you can do that using Program Neighborhood. You can use a HTTP link to launch the Citrix application and that how most Citrix applications are run on the concentrator.
Personally SSL VPN client would be the best choice.
gilbert
mj.jimenez Wed, 03/14/2007 - 09:47
Thank you Gilbert,
but i don't understund you very well, can i use SSL VPN Client to access aplications? How? For what can i use SSL VPN Cient?
