CME 3.3 - 7970G Phones Paging Problems
Answered Question
Running CME 3.3. Paging system on all phones working correctly when using 7040 phones. Replacing 7040 phones with 7970G phones.
When I installed 7970G phones I started having this problem.
When someone "Pages" I noticed on the 7970G phones the page comes through on the phone but the "Speaker" button never comes on and you don't hear the page unless you manually "hit" the button. How do I get the speaker to "Automatically" come on when someone pages.
Correct Answer by paolo bevilacqua about 10 years 2 months ago
This happens because the tftp server gets confused by "flash:" prepended to filename, so please use the alias command in tftp-server, eg:
tftp-server flash:/apps70.1-1-3-31.sbn alias apps70.1-1-3-31.sbn
This way you can store the phoneloads in a separate directory if your router supports that (28xx, 38xx)
repeat for all .sbn files with the exact filenames, and the SCCP70.8-0-4SR3A.loads
As load please configure SCCP70.8-0-4SR3A without the .loads extension.
In fact you can even not use the .default. files at all because you are forcing the upgrade by exact filename.
Overall Rating: 5 (1 ratings)
paolo bevilacqua Mon, 03/12/2007 - 09:13
  • Hall of Fame,
    Founding Member
Firmware on the 7970? Check that you have the lastest 8.0(4)SR3A and try again.
paolo bevilacqua Mon, 03/12/2007 - 11:57
  • Hall of Fame,
    Founding Member
Copy all the files to the router, that should be tftp server. Configure all the files with "tftp-server ....". Configure the load like SCCP70.8-0-4SR3A under "telephony-service", without the extension.
To monitor the upgrade, do "term mon" and "debug tftp-events"
paolo bevilacqua Tue, 03/13/2007 - 09:12
  • Hall of Fame,
    Founding Member
Yes for tidiness remove unused files and configuration commands.
Does the 7970 pages correctly now ?
Correct Answer
paolo bevilacqua Tue, 03/13/2007 - 10:58
  • Hall of Fame,
    Founding Member
