static route administrative distance via radius
Mar 12th, 2007
I have a router with two adsl lines, one primary, one backup, terminated to the same LNS. I want to assign a static route for the same network to each of them with a higher administrative distance for the second and I want to do it via radius using cisco av-pair.
So far I haven't found any link showing that it can be done.
I have found this: Cisco-AVPair = ?ip:route=20.1.3.0 255.255.255.0 172.31.229.41"
but never anything like this:
Cisco-AVPair = ?ip:route=20.1.3.0 255.255.255.0 172.31.229.41 200"
Can you please tell me if it can be done or provide a link?
Thank you in advance.
dsweeny Fri, 03/16/2007 - 07:49
You can use the command "Cisco-AVPair = ?ip:route=20.1.3.0 255.255.255.0 172.31.229.41 200" with RADIUS if you configure it for route download (aaa route download). Some other options to be made are Framed IP address and Net masks should be configured.
As a sample configuration
cisco-avpair = "ip:route=172.18.7.0 255.255.255.0 10.254.40.7 180"
Service-Type = Framed-User
Framed-Protocol = PPP
Framed-IP-Address = 10.254.40.7
Framed-IP-Netmask = 255.255.255.255
Framed-Routing = None
Framed-MTU = 1500
aaa route download
