BR1310 power injector red when power is removed, and restored.
Have a set of BR1310G-A-K9-R with AIR-PWRINJ-BLR2 injectors, feed by P/N 34-1537-02 REVA0.
If 1310 connected to injector, powered by the transformer (mentioned above)when power applied, red light between power plug and coax connector is red, no lights on back of 1310. If I then disconnect the power plug from the injector, and reconnect, same light turns green.
Any suggestions? I didn't purchase the equipment, perhaps the parts listed above are not compatible?
Thanks for any help,
Jeff
Edit missing number.
bwilmoth Fri, 03/16/2007 - 09:40
  • Silver, 250 points or more
Check for loose connections.the maximum distance between BR1310 and power injector is 100m.If this doesnt work Try to replace the power injector and see if it works.Perhaps replacing the power injector mostly would resolve.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
