New to TACACS+/Cisco Secure ACS
Mar 12th, 2007
I am new to using this product & I have a couple of questions..I have users configured & the groups configured (Admin & ReadOnly)..I'm having difficulty with the syntax on my routers & switches when defining the rights/privileges for the admins & readonly users..Does anyone have a sample config that would help..
thanks,
Overall Rating: 5 (1 ratings)
Vivek Santuka Mon, 03/12/2007 - 06:25
Looks like your are trying to configure command authorization ie. control what command which user can execute on the device.
There are two ways to do it :-
1. Define the commands which each privilege level has access to on the device locally
2. Control the commands a group of user can enter on which device via ACS.
Let us know which one you are trying to configure and I will give a sample config.
Vivek
tsingletary Tue, 03/13/2007 - 11:47
Number #2 sounds more like it..Control what access/commands a group can do
Vivek Santuka Wed, 03/14/2007 - 06:03
For that you need exec authentication and command authorization on the device and shell command authorization set on ACS.
So on the device you would need the following minimum commands :-
aaa new-model
aaa authentication login default group tacacs+ local
aaa authorization command 1 default group tacacs+ local
aaa authorization command 15 default group tacacs+ local
tacacs-server host key
On the ACS side, the following link will help :-
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_soft/csacs4nt/acs33/user/c.htm#wp697557
Vivek
