Unity Express Voicemail Time
Answered Question
Mar 12th, 2007
I searched for the answer to this, and found a couple things to try, but wanted to ask just to see if I can get a true answer quicker. Thanks in advance!
With the DST changes, I have all my routers correctly configured. But my voicemail timestamps are still an hour behind. Ive read that it works off NTP, and I should make sure I ping the NTP from the service-engine, I can do that.
It is sitll an hour off though, I guess it may be possible that the NTP server is not upgraded yet..... Any suggestions?
Correct Answer by m-ketchum about 10 years 1 week ago
Go into the service module and change the timezone as a workaround until you have time to upgrade to a newer sofware release that has the DST updates. It has a clock seperate from the router.
Overall Rating: 5 (1 ratings)
ccthompson Mon, 03/12/2007 - 07:12
Has anyone found a solution for Unity Express?
Is there a way I can do this manually, instead of using NTP, or a way to use the network or router time instead of NTP?
Thanks!
Correct Answer
m-ketchum Tue, 03/20/2007 - 19:05
