IPCC 4.0(4) DST
braclarke Mon, 03/12/2007 - 08:04
Have had a few as well, rebooting the server seemed to clear it up for now.
jacoffeyajc Mon, 03/12/2007 - 11:32
I had the same problem. Unchecking "Automatically adjust clock for DST" and clicking OK corrected it for me. I have not re-enabled it to see if the problem returns.
JASON NIELSEN Mon, 03/12/2007 - 23:22
Thanks for your post....that is what fixed my issue. Has there been a TAC case opened on this?
goodwinscottns Tue, 03/13/2007 - 09:43
It appears that it is absolutely necessary to reboot the IPCC server following the Java updates. If you only restart the CRS Engine, some of the JRE's will not pick up the correct DST offset.
