interesting observation/ possible bug
Mar 12th, 2007
I am still investigating this issue, but here is something discovered using the WCS templates to push out a wlan config to WLC 4402 controllers.
I created a new wlan template with wpa security, etc and broadcast ssid turned off (unchecked), saved it and then applied it to my controllers.
I then opened up the web interface of one of the controllers to verify and saw the new wlan, but it had broadcast ssid enabled! I then went to each controller and discovered the same issue. I do not recall seeing any caveats for this but will check again.
Running WCS ver
wlc ver
laaustin Mon, 03/19/2007 - 06:00
I observed the same phenomena... however, with the massive number of changes I needed to address, I didn't follow up with a TAC case though...
sonjam Tue, 03/20/2007 - 08:25
I saw the same thing only we have WLC ver with WCS Again, I didn't report it either. My bad...
Trending Topics - Security & Network
