Can not upload IOS?
Mar 12th, 2007
I uploaded this IOS to over 200 routers, but one of them is keep returning an error message "Invalid checksum"
router#copy tftp flash:
Address or name of remote host []? x.x.x.x
Source filename []? c2600-ik9o3s-mz.123-21.bin
Destination filename [c2600-ik9o3s-mz.123-21.bin]?
Accessing tftp://x.x.x.x/c2600-ik9o3s-mz.123-21.bin...
Erase flash: before copying? [confirm]
Erasing the flash filesystem will remove all files! Continue? [confirm]
Erasing device... eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee ...erasedee
Erase of flash: complete
Loading c2600-ik9o3s-mz.123-21.bin from x.x.x.x (via Serial0/0.186): !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
[OK - 19741828 bytes]
Verifying checksum... invalid (expected 0xA57, computed 0xA53)
19741828 bytes copied in 6304.583 secs (3131 bytes/sec)
Router#dir
Directory of flash:/
No files in directory
33030144 bytes total (13288252 bytes free)
Any idea what's going on?
Danilo Dy Mon, 03/12/2007 - 07:15
  • Blue, 1500 points or more
I think you are trying to upload the image remotely.
You will encounter this error if the line is busy.
Since you already upload it to over 200 routers, I doubt that there is a problem with the image. However, it wouldn't hurt to run a checksum on the file in your TFTP server and compare it with the checksum from the url where you download the image.
Then, try to upload it again when the line is not busy.
Ahmede Mon, 03/12/2007 - 07:20
Thnaks for your reply.. In act we tried the upload 5 times.. One of them was at 3AM on Sundy morning and there were no activity on the link at all..
Anand Narayana Mon, 03/12/2007 - 07:29
  • Silver, 250 points or more
Hi Ahmed,
i had the similar kind of problem, the only difference is i was uploading the image vis XMODEM utility, because my IOS was corrupted, so i tried recovering using the XMODEM utility, it was uploading but finally with the error message "invalid check..." so finally we changed the flash & uploaded using the same procedure, it worked out, so if you ask me, try using the XMODEM utility if not try changing the FLASH as an last option.
Note: i tried this on Cisco 3640
