QoS Config Question
We have a Cisco ASA 5510 connecting our internal network to the Internet using a T1 circuit.
Often, a single person downloading a file from the Internet causes bandwidth usage to spike to the full 1.4Mb and to the detriment of other users.
Can someone please suggest the particular QoS config for being able to more equitably share bandwidth among connections?
Thanks in advance.
Ahmadali
suschoud Mon, 03/12/2007 - 10:18
  • Gold, 750 points or more
Unfortunately, the PIX firewall has no feature set to manage bandwidth per user. On PIX
7.0 code, we have included QoS feature which is a traffic-management strategy that lets
you allocate network resources for both mission-critical and normal data, based on the
type of network traffic and the priority you assign to that traffic. In short, QoS ensures
unimpeded priority traffic and provides the capability of rate-limiting (policing) default
traffic.
Here is some information on Applying QoS Policies :
http://www.cisco.com/en/US/products/sw/secursw/ps2120/products_configuration
_guide_chapter09186a0080450b9a.html
abinjola Mon, 03/12/2007 - 10:27
  • Cisco Employee,
hello AA..
why dont you determine first what type of download is it...ftp,peer to peer, web, etc
1) Once we determine the type of protocol this download happens then we can apply the rate limiting for that protocol
2)Or else if there is a specific subnet or host that does this download then we can apply a traffic bandwidth for that host/subnet
Thanks for the reply.
In the typical scenario of an internal network connected to the Internet, how would the rate limiting commands be applied?
Would the 'police' command be an 'input' or 'output'?
Which interface would the service-policy be applied to? The internal one, or the external Internet side?
Thanks again.
abinjola Mon, 03/12/2007 - 12:53
  • Cisco Employee,
well lets assume you want to rate limit for everything and anything thats accessed then following are the commands needed to limit it for 5mbps (Lets assume you need 5 mbps)
class-map police_traffic
match any
policy-map qos
class police_traffic
police output 5000000 5000000
service-policy qos interface inside
Look at the match command ...here you can refine this by using an access-list, protocol instead of "any"
