CSS 11500 XML configuration
Mar 12th, 2007
I know you can configure the content switch using an xml file. Is there a way to export the current config to XML format? It's for reporting use.
Kind regards.
Frederik De Muyter.
Syed Iftekhar Ahmed Mon, 03/12/2007 - 15:02
  • Blue, 1500 points or more
I dont think CSS is able to send the running configuration in XML configuration off the CSS.
If you want to configure CSS using XML then its definitely possible. Attached with this is a chapter from CSS user guide which shows a complete XML file to create services & Content rule on CSS.
Syed Iftekhar Ahmed
Syed Iftekhar Ahmed Mon, 03/12/2007 - 15:03
Syed Iftekhar Ahmed
