Slow Network.
kalpeshcisco
Hi all,
This is just an general question. We have two subnets on our network. Both these networks are routed. We have Cisco 1721 Router. It has only one Ethernet Module. We cannot user another. It is the gateway for subnet1 and subnet2. subnet2 gateway is defined as secondary. We have several cisco 2950 series switches. All our server are in subnet1.
Now to say, anyone in subnet2 trying to access resourses like servers, network printers which are in subnet1, the responce time is very slow. Like you click on a file to save / print, it takes long time. Whereas users on subnet1 have no problems (since all resources are on same subnet).
I guess we need to either upgrade the router or connect a layer 3 switch.
Is the network on subnet2 experiencing slow response since its gateway is defines as secondary ? I mean to ask, does this effect in any such way ?
Please give some suggestions. Hope am clear.
thanks,
abc.
3 Accepted Solutions
Look at the device interface settings on whatever is connected to the other end . That end must be 100/full also , you appear to be taking a lot of crc's . The interface is not overloaded , the 5 minute input and output rate is less than 1 meg per sec . Suspect a link mismatch .
Try setting both sides to autonegotiate if you haven't already, to clear up the CRC/input errors/etc. The traffic is routed through that Ethernet interface, so if it's taking errors you are certain to see some degredation.
I've had problems with 2950s being hardcoded recently, as well as the devices on the opposite end being hardcoded. Same symptoms as yourself.
Setting both sides to auto is worth a try, but if that doesn't help you need to try another switch port. If still seeing errors the next step would be to swap out the router.
15 Replies 15
glen.grant
That is your problem most likely as it has to be routed from one address range to another. It is also a 10 meg half duplex link and any utilization above like 35% will start to see degradation on response time . Look at the utlization on that interface and figure out how much load there is on it . A layer 2/3 switch would be much faster if you don't need serial links .
dgahm
Level 8
Level 8
Both your subnets are on the same layer 2 broadcast domain, but must talk to each other through the router. This is not a really optimum situation, but shouldn't cause the slowness unless your traffic levels are exceeding the ability of the router. Can you post the output of a show interface fas0? Are you seeing any errors? A duplex mismatch could be another explanation for slowness.
Please rate helpful posts.
Dave
Thanks for reply.
Please find the output as below,
R1#show int fastEthernet 0
FastEthernet0 is up, line protocol is up
Hardware is PQUICC_FEC, address is 000d.285a.9024 (bia 000d.285a.9024)
Internet address is 192.168.4.1/24
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 254/255, txload 1/255, rxload 1/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:00, output 00:00:00, output hang never
Input queue: 2/75/12140/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 473000 bits/sec, 89 packets/sec
5 minute output rate 474000 bits/sec, 85 packets/sec
517118065 packets input, 4228616988 bytes
Received 28549825 broadcasts, 0 runts, 0 giants, 0 throttles
4978622 input errors, 4978594 CRC, 0 frame, 28 overrun, 0 ignored
0 watchdog
455906349 packets output, 3363327833 bytes, 5243 underruns
5243 output errors, 0 collisions, 4 interface resets
0 lost carrier, 0 no carrier
I agree that the router is over-loaded. Like we have Email Server at HO. So mail traffic is huge throughout the day.
Can i use 2950 switch to route the traffic between these networks rather than going to the router ? Will that make difference if possible ?
Thanks again.
abc.
A 2950 is a layer 2 switch, so no.
Also, look at the CRCs in the output above. Clear your counters and let it run for an hour and check it again.
Sorry for late response. Hope excused.
The other end is a switch and is 100/full.
How to resolve the CRC errors ?
How to check the link mismatch ?
thanks,
abc.
Can you post a show interface from the switch side?
Did you clear counters on both sides to confirm the CRCs errors are incrementing?
You could have a bad cable. Do you have a new, or known good, cable you could replace it with?
Thanks for reply,
I cleared the counters on Router. Yet there are CRC errors. Yet there are CRC errors in the Router. I will change the cable with a branded good cable.
then will clear the counters again and post the sh int from Router and Switch together.
abc.
I changed the cables with new/good ones.
Then cleared the counters.
Further to mention, The router is not directly connected to the switch. We have a compression router in between. The connection from router goes to this device and then to the switch. (Sorry, i did not mention that in earlier post).
But i disconnected the compression router and connected the main router directly to the switch. Yet the CRC errors are incrementing.
There are no such errors on the Switch Port it is connected to.
Please find the sh int output in the attached files. The "First" is with compression router connected, "Second" is without it/direct to the switch.
To mention, the ping from subnet1 to subnet2 or vice versa, drops packets (with request time out) with every 15-20 replies.
Hope i am clear. Thanks,
abc.
The switch show interface indicates an input/output rate of 0. Are you sure that is the correct interface? Does a show cdp neighbors confirm this?
Yes, cdp neighbors shows it is connected to this switch on fa 0/3 port.
Also i changed the cable with new one. Its confirmed.
here is the output from the switch
Switch#sh int fa 0/3
FastEthernet0/3 is up, line protocol is up
Hardware is Fast Ethernet, address is 000b.5f6d.d383 (bia 000b.5f6d.d383)
MTU 1500 bytes, BW 100000 Kbit, DLY 1000 usec,
input flow-control is off, output flow-control is off
Last input 00:00:11, output 00:00:00, output hang never
Last clearing of "show interface" counters 23:12:30
Output queue :0/40 (size/max)
2484915 packets input, 1380529566 bytes, 0 no buffer
Received 32473 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog, 19193 multicast, 0 pause input
3123516 packets output, 1150719639 bytes, 0 underruns
10 output errors, 14 collisions, 0 interface resets
0 babbles, 10 late collision, 39 deferred
abc.
Well, to clear myself, i set both sides to auto as below,
Switch(config)#int fa 0/3
Switch(config-if)#speed auto
Router(config)#int fa 0
Rotuer(config-if)#speed auto
Yet i do not see any input/output packets in the switch. But there are no CRC errors on the Router doing sh int fa 0. Today its off day. May be i can give the exact results tommorrow. The output is as below,
Router#sh int fa 0
Last clearing of "show interface" counters 00:20:53
5 minute input rate 31000 bits/sec, 12 packets/sec
5 minute output rate 29000 bits/sec, 10 packets/sec
37936 packets input, 12235932 bytes
Received 3491 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog
34658 packets output, 12164590 bytes, 0 underruns
Last input 00:00:42, output 00:00:01, output hang never
Last clearing of "show interface" counters 00:23:43
34869 packets input, 13125241 bytes, 0 no buffer
Received 462 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog, 332 multicast, 0 pause input
39742 packets output, 13005237 bytes, 0 underruns
abc.
