New VPN setup
Mar 12th, 2007
I am new to Cisco technology and would like to set up VPN capability for remote users. We have an 871 router with 1 public IP address and an internal Windows network that uses PAT to access the internet. Could someone please provide a link or information on how to get started configuring VPN.
Overall Rating: 4 (1 ratings)
ggilbert Mon, 03/12/2007 - 08:42
  • Cisco Employee,
The document listed below has information on how to configure a VPN client to an ASA.
And it also provides you information on allowing the VPN client to access internet through the ASA while connected through VPN client.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00805734ae.shtml
Rate this post, if it helps.!!
Cheers
Gilbert
jmarsh8034 Wed, 03/14/2007 - 05:32
Do I need to purchase an ASA or can I use the 870 series router as a VPN server. I need to allow outside users access to my server that is located inside my LAN. We will need up to 10 VPN tunnels for remote users, but no site to site lines. If I do need to purchase more equipment does anyone have a suggestion?
ggilbert Wed, 03/14/2007 - 08:02
  • Cisco Employee,
You do not need to purchase more equipments.
you can use the 870 series router to provide VPN client connections to your network.
All you need in the router is to make sure that you have right software running.
Send the output of "sh ver" please.
Let me take a look at it to see if you have the ability to configure crypto.
Gilbert
jmarsh8034 Wed, 03/14/2007 - 09:40
Here is my version. Please let me know if you need anything else.
Cisco IOS Software, C870 Software (C870-ADVSECURITYK9-M), Version 12.4(4)T4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Thu 03-Aug-06 17:20 by kellythw
ROM: System Bootstrap, Version 12.3(8r)YI3, RELEASE SOFTWARE
FMG uptime is 1 day, 3 hours, 38 minutes
System returned to ROM by reload
System image file is "flash:c870-advsecurityk9-mz.124-4.T4.bin"
Last reload reason: Unknown reason
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 871W (MPC8272) processor (revision 0x200) with 118784K/12288K bytes of memory.
Processor board ID FHK104813BP
MPC8272 CPU Rev: Part Number 0xC, Mask Number 0x10
5 FastEthernet interfaces
1 802.11 Radio
128K bytes of non-volatile configuration memory.
24576K bytes of processor board System flash (Intel Strataflash)
ggilbert Wed, 03/14/2007 - 09:58
  • Cisco Employee,
you should not have a problem with configuring "crypto" on this router.
Gilbert
jmarsh8034 Wed, 03/14/2007 - 11:00
Do you know of a link to something that will show me how to set this up?
Jason
ggilbert Wed, 03/14/2007 - 11:05
  • Cisco Employee,
Jason,
Here is the link for that.
http://www.cisco.com/en/US/products/sw/secursw/ps2308/products_configuration_example09186a00801c4246.shtml
The only thing is, the VPN client is little bit different now. The version out on CCO is 4.8 version but the configuration pretty much is the same.
This document was created when cisco first supported VPN client to terminate on Cisco IOS routers.
Cheers
Gilbert
