2851 router in rommon
Mar 12th, 2007
hi
my router is in rommon mode how can i get back to normal operation its not taking the confreg 0x2102 also
i think the image is got corrupted
how can i upload new image.
ur suggestion will be highly appreciated
regards
sandeep pokhriyal Mon, 03/12/2007 - 08:31
when i do
dir flash
the router is showing an error
open error=-66
dir:cannot open device flash
Danilo Dy Mon, 03/12/2007 - 09:04
Contact your vendor then, the flash maybe faulty. The error -66 looks like hardware, can't find it in Cisco web
sandeep pokhriyal Mon, 03/12/2007 - 10:01
i think this is the matter as i used one router flash this is working not giving this error.
i m trying with other router flash which is 32mb only mine was 64 but the ios will come in this as its only 28mb.
i will make this router running and when will get new flash will replace well thanks for your reply .
i will assaign points whn router is up and running.
