Cisco 857 +external management
Hi All,
I configured my Cisco 857 router using the SDM utility. I assume that by default the SDM does not create a configuration whereby management to the router can be done over the Internet (to external IP) using ssh, telnet, etc?
I assume in order to do this I would have to have some access-lists?
I know on the PIX you can specify where management can be done.
drolemc Mon, 03/19/2007 - 06:35
CiscoWorks applications, including CiscoView Resource Manager Essentials and Web-based network and device management applications, installed on a dedicated CiscoWorks server, can be used to manage the Cisco 850 Series and 870 Series. CiscoView can be used to view graphical representations of front and back device panels, configure parameters, and monitor real-time statistics for device performance and resource utilization. Resource Manager Essentials provides tools to support inventory management, device configuration, and software image updates; audit changes in the network; and analyze syslog messages .
