Question about Supervisor 32 (WS-SUP32-GE-3B)
Answered Question
Mar 12th, 2007
We're currently using a 7507 as our core router connecting to multiple providers. We want to replace the 7507 with our 6506. The 6506 has a Supervisor 32 (WS-SUP32-GE-3B). We're thinking of purchasing the L3 license and make this our core router. Our current BGP route is roughly 480K. We're going to add two additional providers and the BGP route will grow over 1K. We love to be able to use the Sup 720 but our budget is limited. We're asking the tech community if the Supervisor 32 will work efficiently in this configuration.
Thank you.
Correct Answer by Danilo Dy about 10 years 1 month ago
Before you add more eBGP peering, I recommend that you upgrade the memory to 512MB.
Overall Rating: 5 (2 ratings)
Danilo Dy Mon, 03/12/2007 - 08:43
  • Blue, 1500 points or more
For BGP the first important resource is Memory, I wonder how you get 480K Prefixes??? You might be receiving even /32 subnets.
Minimum memory requirement for full BGP route is 256MB, recommended is 512MB.
What is your current memory now? Sup32 can upgrade up to 1GB http://www.cisco.com/en/US/products/hw/switches/ps708/prod_bulletin0900aecd801ff3ee.html
nspoftech Mon, 03/12/2007 - 08:54
I meant to say that we have over 480K routes. We currently have 256MB and average memory used is 200MB.
The Sup32 should be ok for us to use since it's upgradeable to 1GB.
Thank you.
Correct Answer
Danilo Dy Mon, 03/12/2007 - 09:03
