rob.huffman Mon, 03/12/2007 - 09:04
Hi Chris,
It needs to be on the Publisher :)
Installing BAT
Before You Begin
The following prerequisites apply to the BAT installation for BAT Release 5.2(3):
Make sure that you are installing BAT on the server that is running the publisher database for Cisco Unified CallManager.
Install BAT directly on the Cisco Unified CallManager server; do not use Terminal Services.
Use the following procedure to install BAT.
Procedure
Step 1 Log on with administrator privileges to the system that is running the publisher database for Cisco Unified CallManager.
Step 2 Choose Applications > Install Plugins. The Install Plugins window displays.
Step 3 Find Cisco Bulk Administration Tool and double-click the setup icon.
Step 4 A standard Windows dialog box appears. You must choose whether to copy the BAT install executable to your system or to run it from the current location.
If an existing version of BAT is detected on the server, a prompt asks you to confirm the reinstallation or upgrade. To reinstall BAT or to upgrade from a previous version, click OK.
Step 5 The Welcome screen displays. Click Next, and the Current Settings window displays.
Step 6 To install to the default location C:\CiscoWebs\BAT\, click Next. BAT installs to C:\ciscowebs\BAT\. You cannot change this path. The Start Copying Files window displays. Setup begins copying files.
Step 7 The Setup Complete window displays. You have successfully installed BAT.
Step 8 To close Setup, click Finish.
From this doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_user_guide_chapter09186a00807184b5.html
Hope this helps!
Rob
