Ciscoworks 2.6 upgrade
Mar 12th, 2007
We have bought a Ciscoworks 2.6 upgrade. We currently run Ciscoworks2000 on a server but want to run the 2.6 on a new separate server.
Questions:
1. DO I have to install Ciscoworks2000 on the new server before i can go up to 2.6?
2. Can I install the Ciscoworks 2.6 fresh on the new server?
David Stanford Mon, 03/12/2007 - 09:44
  • Cisco Employee,
CiscoWorks 2000 is very old, can you check to see what version of Common Services you are running in this bundle?
You can install as an upgrade from a supported version or install clean. If you install clean you will need to run validateupgrade from older CD's or server to validate your upgrade license.
