rajmohan80 Thu, 03/15/2007 - 11:46
Corporate directory search may not be supportd in these ip phones using XML services
jbarcena Thu, 03/15/2007 - 13:33
You might be hitting this bug:
CSCse37151: Phone displays XML Parse Error when accessing Contact List
Symptom:
XML Parser Error on phone when element contains 32 characters.
Conditions:
See Symptom
Workaround:
Shorten the length to 31 or less.
I would also recommend you to upgrade to the latest phone load.
//Jorge
sr2290723 Fri, 06/08/2007 - 01:20
Well, this also happens in my deployment. Thanks for the solution.
Wiyandi
