can the antenna for 340 be used by 1310?
Mar 12th, 2007
a customer deployed Aironet 340 with WISP24015PTNF WISPerformance Series Enclosed Yagi Antenna
I searched the antenna, here're some parameters
Electrical Specifications
Frequency Range 2.4-2.48 GHz
Front to Back Ratio 30 dB
Horizontal Beamwidth 30?
Nominal Gain 15 dBi
Vertical Beamwidth 30?
Mechanical Specifications
Cable 18" coax
Dimensions 14" L x 3" OD
Equivalent Flat Plate Area 0.20 sq. ft.
Lateral Thrust 18.3 lbs
Wind Loading 1 lb
The customer is intended to replace Aironet 340 with AIR-BR1310G-A-K9-T, however keeps the old antennas.
From Cisco Website, I got following info about 1310's antenna.
Antennas for the Cisco Aironet 1300 Series Outdoor Access Point or Bridge with RP-TNC Type Connector
Product Number
Product Description
Cisco Aironet 2.4-GHz, 14-dBi sector antenna
Cisco Aironet 2.4-GHz, 5.2-dBi omnidirectional mast-mount antenna
Cisco Aironet 2.4-GHz, 12-dBi omnidirectional mast-mount antenna
Cisco Aironet 2.4-GHz, 13.5-dBi Yagi antenna
Cisco Aironet 2.4-GHz , 10-dBi Yagi antenna
Cisco Aironet 2.4-GHz, 21-dBi dish antenna
Cisco Aironet 2.4-GHz, 9-dBi patch antenna
Since Cisco doesn't list an antenna with Nominal Gain 15 dBi, I'm not sure if antenna WISP24015PTNF works with Aironet 1310?
Overall Rating: 3 (2 ratings)
john.preves Mon, 03/12/2007 - 12:50
If the new radio has RP-TNC connectors then it will work. However, be advised that those antennas are old enough to be on a 340 then they may be suspect. I would start over with new gear for my enetrprise application and take those home to test with...
scottmac Mon, 03/12/2007 - 13:28
It should work fine.
You should encourage the customer to at least break & reconnect each fitting from the radio to the antenna input, add new weather protectant to the outside joints (Coax-Seal ... I hate it, but it's fairly available (i.e., Radio Shack)), and usually a good idea to replace the (so-called) "lightening arrestor" periodically ... they do age, whether they're hit or not.
Also clean and re-connect the grounding to the masts and shields ... they also oxidize over time and become less effective.
If the yagi elements are bent, twisted, or otherwise out-of-shape, the antenna should be replaced.
Good Luck
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
