Hep with Creating VLANS on my CAT 2948G-L3 Switch
Mar 12th, 2007
I'm trying to create VLANS on this switch but I don't see the commands to do it. I have the following IOS instlaled.
cat2948g-in-mz.120-25.W5.27d.bin
Thanks in advance for the help
Mike
Overall Rating: 3 (1 ratings)
MICHAEL CICCONE Mon, 03/12/2007 - 10:55
Amit,
Here is what I would like to do with this switch. I want to have seprate networks. Say 10.1.1.1/24 and 10.2.1.1/24. I was planning on doing this with two different vlans. Vlan 10 and 11. Then have the two vlans route to the router. I need to the vlans so that I can have x number of ports for the one network and y number of ports for the other network. How can I achive this?
Amit Singh Mon, 03/12/2007 - 11:04
  • Cisco Employee,
Do you have a spare L2 switch. You cannot create L2 vlans on this box. You can use it as an external L3 router for intervlan routing between the vlans. Use a spare L2 switch and uplink it to this box using a trunk link and then create sub-interfaces for the respective vlans for achieving the inter-vlan routing.
-amit singh
MICHAEL CICCONE Mon, 03/12/2007 - 11:20
Amit,
Thanks for the help... Sounds like what your telling me is that I cannot use this switches the way I would like to. I guess I need a 3550 or 3750.
