SIP negotiation fails
Good day.
I have troubles with setting up Cisco2821 for outgoing call via ITSP ICH (part of DeltaThree). Unfortunately, ITSP Support Team answered that they provide full support for PAP2/ATA186 devices only and cannot help with examples/troubleshooting for
another Cisco SIP-compliant devices.
It may be misconfiguration on our side, but i'm not familiar with SIP, and cannot find where is it. Can anyone point right way to solve this issue?
VoIP configuration on our side is:
dial-peer voice 100 voip
answer-address 12068556332
destination-pattern .T
session protocol sipv2
session target ipv4:213.x.x.140:5060
dtmf-relay rtp-nte
sip-ua
authentication username xxxxx password xxxx
retry invite 3
retry response 3
retry bye 3
retry cancel 3
retry register 3
retry options 10
timers trying 1000
timers connect 1000
timers register 1000
sip-server ipv4:213.x.x.140:5060
"debug ccsip messages" shown SIP negotiation (not full debug output placed for minimize
size):
Sent:
INVITE sip:[email protected]:5060 SIP/2.0
Received:
SIP/2.0 100 Trying
Received:
SIP/2.0 407 Proxy Authentication Required
Sent:
ACK sip:[email protected]:5060 SIP/2.0
Sent:
Received:
SIP/2.0 100 Trying
(~30 sec waiting, then)
Sent:
CANCEL sip:[email protected]:5060 SIP/2.0
Received:
SIP/2.0 481 Call Leg/Transaction Does Not Exist
Overall Rating: 3 (2 ratings)
Paolo Bevilacqua Mon, 03/12/2007 - 11:02
Actually it would have been better if you had included the whole debug. The ITSP may be indicating a realm and tha needs to be included in the username configuration.
Paolo Bevilacqua Mon, 03/12/2007 - 13:27
Looks to me the router is authenticating correctly and the ITSP is at fault by not sending any result in 30 sec after the "trying" message.
The only think I can think is to try to set the calling number to be the same as authentication username, this you do with "clid network-provided" under "dial-peer".
Paolo, thank you for responce.
Unfortunately, it did not help to solve problem - ITSP proxy still not respond after "trying".
Our multiple ATA's working fine with ITSP. As i think the difference between SIP negotiation at ATA and Cisco2821 is that ATA register at ITSP proxy.
The one way to resolve problem, as i think, can be emulate ATA on 2821, but there are some moments that i dont know how to set.
Each ATA have 2 FXS ports, connected to PBX. 2821 connected to PBX via ISDN E1 trunk (work fine, and 2 Asterisk in remote offices works fine too).
Maybe somewhere are examples how to emulate ATA in that case?
Paolo Bevilacqua Thu, 03/15/2007 - 12:05
You can have the 2801 register as well.
Configure a secondary number on an ephone-dn of your choice with no-reg primary
in sip-ua, configure "registrar" and "credentials".
Configure "no-register" on all "dial-peer pots".
And let's see if it goes better.
Yes, configuring ephone-dn with secondary number helps to register number on ITSP (got OK, 200).
But this didnt help to place call... Still got timeout after "trying".
I tried to compare SIP Invite packets from ATA and from 2821. The differencies that i found are:
- from ATA goes user=phone, from 2821 goes user=calling
- some differencies in list of "Allow" requests.
I havent any ideas why it didnt work... :(
Packet from ATA-186:
[0:0]Tx Msg to 213.137.73.140:5060
INVITE sip:[email protected];user=phone SIP/2.0
Via: SIP/2.0/UDP 80.249.238.155:5060
To:
Call-ID: [email protected]
CSeq: 1 INVITE
Contact: Line 0
User-Agent: Cisco ATA 186 v3.1.0 atasip (040211A)
Expires: 300
Allow: ACK, BYE, CANCEL, INVITE, NOTIFY, OPTIONS, REFER, REGISTER
Content-Length: 263
Content-Type: application/sdp
Packet from 2821:
Sent:
Via: SIP/2.0/UDP 195.234.72.4:5060;branch=z9hG4bK2AA16E
Remote-Party-ID: ;party=calling;screen=yes;privacy=off
To:
Date: Fri, 16 Mar 2007 15:49:55 GMT
Supported: 100rel,timer,resource-priority,replaces
Min-SE: 1800
Cisco-Guid: 3521911484-3540783579-2156658712-433194112
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1174060195
Contact:
Expires: 300
Allow-Events: telephone-event
Content-Disposition: session;handling=required
Content-Length: 294
Paolo Bevilacqua Sat, 03/17/2007 - 08:02
Sorry, I do not see a clear reason why the calls from the router are not successful. Time to switch to a different ITSP perhaps.
