Getting NAT correct on a 6509
Mar 12th, 2007
I need a little NAT advice. I am routing between 2 internal vlans, 192.168.32.0/24 and .64/24. I need to NAT these 2 vlans to the outside/public vlan 165.x.x.x. Here is the config I have come up wth :
ip nat pool niscpool 165.x.x.105 165.x.x.105 prefix 24
access-list 1 permit 192.168.32.0 0.0.0.255
access-list 1 permit 192.168.64.0 0.0.0.255
ip nat inside source list 1 pool niscpool overload
interface vlan 1
ip nat outside
interface vlan 3
ip nat inside
interface vlan 4
ip nat inside
Will this work? Any suggestions?
TIA
ssoberlik Fri, 03/16/2007 - 11:50
  • Bronze, 100 points or more
If you are planning to implement NAT with Cat6509 supervisor itself, then you cannot go for 2 inside interfaec. Cisco IOS does not allow that configuration.
Refer to http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a00800ca75b.html#wp1003513
But you can implement this scenario with Firewall module FWSM.
You can configure multiple SVIs to be part of the 'inside' interface.
http://www.cisco.com/en/US/products/hw/switches/ps708/products_module_configuration_guide_chapter09186a0080577c7f.html#wp1176033
Jon Marshall Fri, 03/16/2007 - 15:33
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Is this a limitation of the 6500 or the IOS.
As far as i am aware there is nothing to stop you applying the "ip nat inside" statement to more than one interface in IOS.
Jon
