03-12-2007 12:25 PM - edited 03-18-2019 07:04 PM
The times that are showing in my RTMT window are all an hour off. We have applied all the neccessary patches to CM that are listed in the Field Notice. I am wondering though if this is more of a local machine java issue and not a Call Manager issue? I have opened a TAC case but not resolve yet.
Thanks all.
Solved! Go to Solution.
03-12-2007 12:30 PM
You'll probably want to ask this on the IP Telehpony forum, however there are JRE issues with the time conversion - specifically I ran into a situation where it "double jumped" and actually had the time an hour ahead of where it should be - Sun has posted fixes. In my case I applied the latest 1.5 JRE updates and it resolved the issue.
03-12-2007 12:30 PM
03-12-2007 12:33 PM
I will move this over to the other forum. Thanks for the help. Sorry to hear about your double time jump.
