Problem with users in Remote Access by Modem
Mar 12th, 2007
When I try to make Modem conecction from a PC , the only user than permit the conection in the Routers , is the username with the sane name at the prompt of the router .
Before this was unnecesary . How can I put more usernames ??
In the case , the only user that can to connect is "PF-Panamericana" , but pfernandez is unable to connet . The user and pass are OK .
wHY ??
I aatach a configuration .
Best Regards
jcorrale Tue, 03/13/2007 - 12:19
Hi Rodrigo,
I checked the configuration and notice that the username ?PF-Panamericana? has a privilege of 7 while the rest of the users, like ?pfernandez? have no privilege, so the router is not granting access to those users. To create a new username and password with privilege 7, just do it as follows:
Router# config t
Router(config)# username privilege 7 password
Hope it helps!
Juan
