03-12-2007 02:44 PM - edited 02-21-2020 02:55 PM
How do you enable ipsec over tcp on the pix with the vpn client using pix version 6.3?
03-12-2007 05:13 PM
IPSEC over TCP is not supported in 6.3. It is only supported in 7.x versions.
HTH,
Please rate if it helps,
Kamal
11-29-2007 09:10 AM
I'm running an ASA 8.02 and can't get TCP to work. UDP works fine. I'm using a 5.x client. Any help?
