asa5510 and business class dsl problems
Answered Question
Mar 12th, 2007
below is my setup.
business class dsl modem with a static ip (100.0.0.1) connects to a asa5510.
the isp provided me another static routable ip for the asa5510 and I configured the 5510 outside interface with this (100.0.0.2).
I also have couple of machines behind the inside interface of the 5510. (172.16.1.0)
All i want to do is let some ppl vpn into the inside network to do some troubleshooting.
I don't need anyone from the inside to access the net, so no nat needed.
I went through the normal vpn config and the remote vpn wizard.
however, using the cisco vpn client, i'm unable to log in.
I can ping the 100.0.0.1 interface but cannot vpn in.
I think there is no path from 100.0.0.1 to 100.0.0.2
any suggestions?
Correct Answer by ggilbert about 9 years 11 months ago
The group name should be EAT which is configured on the tunnel-group parameters in your ASA. It should not be "vgoradia" but what is configured on the ASA.
And the password should be the one that you have configured under the tunnel-group parameter for pre-shared key.
tunnel-group EAT type ipsec-ra
tunnel-group EAT general-attributes
address-pool vpnpool
default-group-policy EAT
tunnel-group EAT ipsec-attributes
pre-shared-key *
Let me know how this pans out.
Rate this post, if it helps.
Gilbert
Overall Rating: 4.5 (6 ratings)
Kamal Malhotra Mon, 03/12/2007 - 17:03
To begin with, do you have a default route on the ASA that points to the DSL? E.g. :
route outside 0.0.0.0 0.0.0.0 100.0.0.1
HTH,
Please rate if it helps,
Kamal
vgoradia Mon, 03/12/2007 - 17:09
nope, do not have a default route set. I need to do this.
when I setup the cisco easyvpn client s/w, the ip I would want to hit is 100.0.0.2 correct?
how would 100.0.0.1 allow traffic to flow to 100.0.0.2?
what command should I use to make 100.0.0.2 pingable temporarily just to verify that the vpn works.
thanks for all the help. i will rate
Kamal Malhotra Tue, 03/13/2007 - 02:36
To begin with, are you able to ping 100.0.0.1 from 100.0.0.2? If not then you need to talk to your ISP. You might also want to clear the ARP table on the asa using the CLI command 'clear arp'.
Yes you are correct that the IP you would want to hit is 100.0.0.2. Since 100.0.0.2 is directly connected to 100.0.0.1, it will have .2 IP in its ARP table and will ebe able to route correctly.
Route is important even to be able to ping.
HTH,
Kamal
vgoradia Tue, 03/13/2007 - 07:19
ok I cleared the arp table and put in the static route.
now, from the 5510, i can ping the inside machines using the inside interface and I can ping the outside dsl modem using the outside interface.
Also, from the net, I can now ping the ip for the dsl modem as well as the static routable ip for the asa5510 !!!!!!
this is good.
however, I am unable to vpn into the 5510.
the easyvpn client says 'connection terminated by local client' , reason 412.
I tried to play with the different transport, including checking off and on 'transparent runneling'.
any other ideas?
i'm stumped.
i feel i'm very close to this.
any help would be really appreciated!
vgoradia Tue, 03/13/2007 - 08:30
here's my sh run
ASA Version 7.2(2)
hostname ciscoasa
domain-name default.domain.invalid
enable password xxx
names
interface Ethernet0/0
nameif outside
security-level 0
ip address x.x.80.98 255.255.255.252
interface Ethernet0/1
nameif inside
security-level 100
ip address 172.16.4.231 255.255.252.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
management-only
passwd xxx
ftp mode passive
dns server-group DefaultDNS
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
access-list inside_nat0_outbound extended permit ip any 172.16.4.192 255.255.255.192
pager lines 24
logging asdm informational
mtu management 1500
mtu outside 1500
mtu inside 1500
ip local pool vpnpool 172.16.4.220-172.16.4.230 mask 255.255.252.0
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-522.bin
no asdm history enable
arp timeout 14400
nat (inside) 0 access-list inside_nat0_outbound
route outside 0.0.0.0 0.0.0.0 x.x.80.97 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
group-policy EAT internal
group-policy EAT attributes
vpn-tunnel-protocol IPSec
username vgoradia password xxx
privilege 0
username vgoradia attributes
vpn-group-policy EAT
http server enable
http 192.168.1.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map outside_dyn_map 20 set pfs
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-SHA
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
address-pool pool
pre-shared-key *
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:xxx
: end
Kamal Malhotra Tue, 03/13/2007 - 09:05
The config looks good so we need to get debugs from the ASA and the logs from the clients. You might want to remove the PFS from the dynamic cry map. The commands would be :
no crypto map outside_map interface outside
no crypto dynamic-map outside_dyn_map 20 set pfs
HTH,
Please rate if helps,
Kamal
vgoradia Tue, 03/13/2007 - 09:08
what commands do I enable for debugs from the asa and from the client?
thanks
ggilbert Tue, 03/13/2007 - 09:15
On the ASA you would need to run
deb cry isa 128
deb cry ipsec 128
And on the clients, go to the "Log" section
a. Enable Log
b. Go to log settings and change the severity of the logs to 1-3
Open the log window -
Connect and send the logs & debugs.
Gilbert
vgoradia Tue, 03/13/2007 - 09:29
is there a cisco url where I can see a config for a basic remote access vpn on an asa device.
I don't even need to NAT and all the other stuff....
I would've thought that this would be the simplest config of all....
what's compounding the fact is that this device is in a different bldg from where I am and I have to go over everytime to make a change.
and since they do not have a phone line, I have to come back to my office and dial out to an isp and then try to vpn in!!!
(since we do not allow vpn traffic out of our work LAN)
also, is there a way I can manage the asa5510 through it's outside interface since I can ping it?
thanks once again for staying with me.
ggilbert Tue, 03/13/2007 - 10:03
This example gives you an idea on how to configure it.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a008046f307.shtml
(Even though it says PIX, it can be used for ASA as well).
Here is another example for VPN client to connect to an ASA and also allow access through the ASA to the internet.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00805734ae.shtml
You can access your ASA through the outside interface. You can use ssh or ASDM.
ssh 0.0.0.0 0.0.0.0 outside
Use a "putty client" or some ssh client and you should be able to access the ASA.
Use the username pix which is by default.
Gilbert
Rate this post, if it helped.
vgoradia Tue, 03/13/2007 - 11:49
ok, i modified the settings on the 5510 and still no go.
here's the log from the vpn client.
I could not ssh into the asa from my dial up...and niether could I use the asdm..it just timed out.....
i'm at my wits end!
please help
Cisco Systems VPN Client Version 4.8.02.0010
Copyright (C) 1998-2006 Cisco Systems, Inc. All Rights Reserved.
Client Type(s): Windows, WinNT
Running on: 5.1.2600 Service Pack 2
Config file directory: C:\Program Files\Cisco Systems\VPN Client
1 14:36:23.545 03/13/07 Sev=Info/6 GUI/0x63B00011
Reloaded the Certificates in all Certificate Stores successfully.
1 14:36:44.915 03/13/07 Sev=Info/4 PPP/0x63200015
Processing enumerate phone book entries command
2 14:36:44.986 03/13/07 Sev=Info/4 PPP/0x6320000D
Retrieved 2 dial entries
3 14:36:56.532 03/13/07 Sev=Info/4 CM/0x63100002
Begin connection process
4 14:36:56.582 03/13/07 Sev=Info/4 CM/0x63100004
Establish secure connection
5 14:36:56.582 03/13/07 Sev=Info/4 CM/0x63100024
Attempt connection with server "x.x.80.98"
6 14:36:56.592 03/13/07 Sev=Info/6 IKE/0x6300003B
Attempting to establish a connection with x.x.80.98.
7 14:36:56.622 03/13/07 Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK AG (SA, KE, NON, ID, VID(Xauth), VID(dpd), VID(Unity)) to x.x.80.98
8 14:36:56.863 03/13/07 Sev=Info/4 IPSEC/0x63700008
IPSec driver successfully started
9 14:36:56.863 03/13/07 Sev=Info/4 IPSEC/0x63700014
Deleted all keys
10 14:36:56.863 03/13/07 Sev=Info/4 IPSEC/0x6370000D
Key(s) deleted by Interface (x.x.34.170)
11 14:36:56.863 03/13/07 Sev=Info/4 IPSEC/0x6370000D
Key(s) deleted by Interface (x.x.55.131)
12 14:37:01.860 03/13/07 Sev=Info/4 IKE/0x63000021
Retransmitting last packet!
13 14:37:01.860 03/13/07 Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK AG (Retransmission) to x.x.80.98
14 14:37:06.867 03/13/07 Sev=Info/4 IKE/0x63000021
15 14:37:06.867 03/13/07 Sev=Info/4 IKE/0x63000013
16 14:37:11.874 03/13/07 Sev=Info/4 IKE/0x63000021
17 14:37:11.874 03/13/07 Sev=Info/4 IKE/0x63000013
18 14:37:16.881 03/13/07 Sev=Info/4 IKE/0x63000017
Marking IKE SA for deletion (I_Cookie=0D933CECB69B085E R_Cookie=0000000000000000) reason = DEL_REASON_PEER_NOT_RESPONDING
19 14:37:17.402 03/13/07 Sev=Info/4 IKE/0x6300004B
Discarding IKE SA negotiation (I_Cookie=0D933CECB69B085E R_Cookie=0000000000000000) reason = DEL_REASON_PEER_NOT_RESPONDING
20 14:37:17.402 03/13/07 Sev=Info/4 CM/0x63100014
Unable to establish Phase 1 SA with server "x.x.80.98" because of "DEL_REASON_PEER_NOT_RESPONDING"
21 14:37:17.442 03/13/07 Sev=Info/5 CM/0x63100025
Initializing CVPNDrv
22 14:37:17.472 03/13/07 Sev=Info/6 CM/0x63100046
Set tunnel established flag in registry to 0.
23 14:37:17.472 03/13/07 Sev=Info/4 IKE/0x63000001
IKE received signal to terminate VPN connection
24 14:37:18.514 03/13/07 Sev=Info/4 IPSEC/0x63700014
Deleted all keys
25 14:37:18.514 03/13/07 Sev=Info/4 IPSEC/0x63700014
Deleted all keys
26 14:37:18.514 03/13/07 Sev=Info/4 IPSEC/0x63700014
Deleted all keys
27 14:37:18.514 03/13/07 Sev=Info/4 IPSEC/0x6370000A
IPSec driver successfully stopped
ggilbert Tue, 03/13/2007 - 12:06
Send me the output of the following
sh run ssh
sh cry key mypubkey rsa
from the ASA.
Gilbert
vgoradia Tue, 03/13/2007 - 12:25
here you go...looks like the pubkey is blank.
ciscoasa# sh run ssh
ssh timeout 5
ciscoasa# sh cry key mypubkey rsa
ciscoasa#
ggilbert Tue, 03/13/2007 - 12:29
Issue this command on the ASA
cry key gen rsa modu 1024
Try the ssh again from the client - see if you can access the ASA.
Gilbert
Rate this, if it helps.
vgoradia Tue, 03/13/2007 - 12:50
good news and bad news.
the good news is that ssh works.
the bad news is that I'm unable to logon with my password.
I tried to login as 'admin' 'pix' and blank and I input my enable/console password and it didn't take any!
also, I tried the vpn client and it failed.
I tried to login thru ipsec/tcp port 10000 and it established tcp connection and then tried to send the ISAKMP OAK AG packet but no response from the 5510.
anything else I can try? and what can I use to logon thru ssh.
ggilbert Tue, 03/13/2007 - 16:07
Hello Vishal,
Lets divide and conquer instead of putting every problem in the same basket.
Lets fix the ssh issue first.
So, the ASA has two password. Normal telnet password and enabled password.
When you ssh into the ASA, use the username "pix" and telnet password
Then you will get the prompt for enable
ASA>
After that, type enable and insert the enable password. You should be able to log in.
Please rate this topic, if it helps.
Gilbert
vgoradia Tue, 03/13/2007 - 19:16
Gilbert,
good news is ssh issue is resolved.
bad news is that i'm an idiot.
I had not set a telnet password and didn't realize this.
i used the default username and the default password and sure enough, it let me in.
so i'm all set with ssh which is a great relief bcoz now I do not have to go on site to configure the 5510. I can sit in my office and play with it and then dial out to an isp to test the vpn.
so what's next...guru?
ggilbert Wed, 03/14/2007 - 05:49
Vishal,
Good to hear that you got it working.
Now, lets get the VPN client to work.
ssh into your ASA and enable the debugs
"deb cry isa 128" & "deb cry ipsec 128"
issue the command "term mon"
Connect with your VPN client and lets see where this is failing.
Run the logs on the client at the same time you are trying to connect.
Attached both - the debugs and the logs - let me take a look at them.
Cheers
Gilbert
vgoradia Wed, 03/14/2007 - 07:29
this is what the term mon shows which may explain the whole problem...
the x.x.105.96 IP is the machine that has the vpn client trying to connect to the 5510.
ciscoasa# Mar 14 14:22:50 [IKEv1]: IP = x.x.105.96, No crypto map bound to interface... dropping pkt
Mar 14 14:22:55 [IKEv1]: IP = x.x.105.96, No crypto map bound to interface... dropping pkt
Mar 14 14:23:00 [IKEv1]: IP = x.x.105.96, No crypto map bound to interface... dropping pkt
Mar 14 14:23:05 [IKEv1]: IP = x.x.105.96, No crypto map bound to interface... dropping pkt
ggilbert Wed, 03/14/2007 - 07:53
Are you connecting to the interface with the IP "x.x.80.98" - as per your ASA configuration posted previously.
If so, can you please apply this command
cry map outside_map interface outside
Run the commands again - see if it gets connected. :)
Cheers
Gilbert
vgoradia Wed, 03/14/2007 - 08:09
no dice.
the x.x.80.98 is the outside int of 5510. this is a routable ip.
the x.x.105.96 is the ip of the vpn client which is trying to establish a vpn connection with the 5510.
this is what I got from term mon
ciscoasa# debug cry isa 128
ciscoasa# debug cry ipsec 128
ciscoasa# term mon
ciscoasa# Mar 14 15:01:40 [IKEv1]: IP = x.x.105.96, IKE_DECODE RECEIVED Message (msgid=0) with payloads : HDR + SA (1) + KE (4) + NONCE (10) + ID (5) + VENDOR (13) + VENDOR (13) + VENDOR (13) + NONE (0) total length : 808
Mar 14 15:01:40 [IKEv1 DEBUG]: IP = x.x.105.96, processing SA payload
Mar 14 15:01:40 [IKEv1 DEBUG]: IP = x.x.105.96, processing ke payload
Mar 14 15:01:40 [IKEv1 DEBUG]: IP = x.x.105.96, processing ISA_KE payload
Mar 14 15:01:40 [IKEv1 DEBUG]: IP = x.x.105.96, processing nonce payload
Mar 14 15:01:40 [IKEv1 DEBUG]: IP = x.x.105.96, processing ID payload
Mar 14 15:01:40 [IKEv1 DEBUG]: IP = x.x.105.96, processing VID payload
Mar 14 15:01:40 [IKEv1 DEBUG]: IP = x.x.105.96, Received xauth V6 VID
Mar 14 15:01:40 [IKEv1 DEBUG]: IP = x.x.105.96, Received DPD VID
Mar 14 15:01:40 [IKEv1 DEBUG]: IP = x.x.105.96, Received Cisco Unity client VID
Mar 14 15:01:40 [IKEv1 DEBUG]: Group = DefaultRAGroup, IP = x.x.105.96, processing IKE SA payload
Mar 14 15:01:40 [IKEv1 DEBUG]: Group = DefaultRAGroup, IP = x.x.105.96, IKE SA Proposal # 1, Transform # 9 acceptable Matches global IKE entry # 1
Mar 14 15:01:40 [IKEv1 DEBUG]: Group = DefaultRAGroup, IP = x.x.105.96, constructing ISAKMP SA payload
Mar 14 15:01:40 [IKEv1 DEBUG]: Group = DefaultRAGroup, IP = x.x.105.96, constructing ke payload
Mar 14 15:01:40 [IKEv1 DEBUG]: Group = DefaultRAGroup, IP = x.x.105.96, constructing nonce payload
Mar 14 15:01:40 [IKEv1 DEBUG]: Group = DefaultRAGroup, IP = x.x.105.96, Generating keys for Responder...
Mar 14 15:01:40 [IKEv1 DEBUG]: Group = DefaultRAGroup, IP = x.x.105.96, constructing ID payload
Mar 14 15:01:40 [IKEv1 DEBUG]: Group = DefaultRAGroup, IP = x.x.105.96, constructing hash payload
Mar 14 15:01:40 [IKEv1 DEBUG]: Group = DefaultRAGroup, IP = x.x.105.96, Computing hash for ISAKMP
Mar 14 15:01:40 [IKEv1 DEBUG]: Group = DefaultRAGroup, IP = x.x.105.96, constructing Cisco Unity VID payload
Mar 14 15:01:40 [IKEv1 DEBUG]: Group = DefaultRAGroup, IP = x.x.105.96, constructing xauth V6 VID payload
Mar 14 15:01:40 [IKEv1 DEBUG]: Group = DefaultRAGroup, IP = x.x.105.96, constructing Fragmentation VID + extended capabilities payload
Mar 14 15:01:40 [IKEv1 DEBUG]: Group = DefaultRAGroup, IP = x.x.105.96, constructing VID payload
Mar 14 15:01:40 [IKEv1 DEBUG]: Group = DefaultRAGroup, IP = x.x.105.96, Send Altiga/Cisco VPN3000/Cisco ASA GW VID
Mar 14 15:01:40 [IKEv1]: IP = x.x.105.96, IKE_DECODE SENDING Message (msgid=0) with payloads : HDR + SA (1) + KE (4) + NONCE (10) + ID (5) + HASH (8) + VENDOR (13) + VENDOR (13) + VENDOR (13) + VENDOR (13) + NONE (0) total length : 352
Mar 14 15:01:40 [IKEv1 DEBUG]: Group = DefaultRAGroup, IP = x.x.105.96, IKE AM Responder FSM error history (struct &0x3f6c458) , : AM_DONE, EV_ERROR-->AM_SND_MSG2, EV_SND_MSG-->AM_SND_MSG2, EV_START_TMR-->AM_BLD_MSG2, EV_BLD_MSG2_TRL-->AM_BLD_MSG2, EV_SKEYID_OK-->AM_BLD_MSG2, NullEvent-->AM_BLD_MSG2, EV_GEN_SKEYID-->AM_BLD_MSG2, EV_BLD_MSG2_HDR
Mar 14 15:01:40 [IKEv1 DEBUG]: Group = DefaultRAGroup, IP = x.x.105.96, IKE SA AM:b53d7823 terminating: flags 0x0104c001, refcnt 0, tuncnt 0
Mar 14 15:01:40 [IKEv1 DEBUG]: Group = DefaultRAGroup, IP = x.x.105.96, sending delete/delete with reason message
Mar 14 15:01:40 [IKEv1]: Group = DefaultRAGroup, IP = x.x.105.96, Removing peer from peer table failed, no match!
Mar 14 15:01:40 [IKEv1]: Group = DefaultRAGroup, IP = x.x.105.96, Error: Unable to remove PeerTblEntry.
Also, on the vpn client, the reason for failure was because of "DEL_REASON_IKE_NEG_FAILED"
ggilbert Wed, 03/14/2007 - 08:23
Ok - Lets go step by step.
I need the following...
a. current config on the ASA.
b. If you go to the client, what is the groupname you have entered.
vgoradia Wed, 03/14/2007 - 08:33
groupname --> vgoradia
ASA Version 7.2(2)
hostname ciscoasa
enable password xxx
names
nameif outside
security-level 0
nameif inside
security-level 100
ip address 172.16.4.x 255.255.252.0
nameif management
security-level 100
management-only
passwd xxx
ftp mode passive
access-list inside_nat0_outbound extended permit ip any 172.16.4.0 255.255.252.0
pager lines 24
logging enable
mtu management 1500
mtu outside 1500
mtu inside 1500
arp timeout 14400
ipsec-udp enable
ipsec-udp-port 10000
username xxx password xxxx
privilege 15
http server enable
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp ipsec-over-tcp port 10000
pre-shared-key *
telnet timeout 5
ssh timeout 5
console timeout 5
management-access inside
parameters
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
Cryptochecksum:xxxx
: end
ciscoasa#
Correct Answer
ggilbert Wed, 03/14/2007 - 08:50
pre-shared-key *
Gilbert
