Cisco Network Assistant 5.0 5.1
Answered Question
Mar 12th, 2007
Previously I have used CNA 4.1 without problems.
Recently installed CNA 5.0 and upon running the app received a java error "Could not create the Java virtual machine"
Uninstalled this and went back to 4.1 which operated fine.
Have just installed CNA 5.1 and it give the same java error again.
Uninstalled 5.1 and installed 4.1 and its all fine again.
Has anyone else come across this and is there a resolution on how to fix.
BTW have also tried different JRE editions such 1.4 and 1.5.
Current:
M:\>java -version
java version "1.5.0_11"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_11-b03)
Java HotSpot(TM) Client VM (build 1.5.0_11-b03, mixed mode, sharing)
edit: should also mention that I have tried installing in different DIR's and changing the security to "full control" inheritive.
Correct Answer by reiner.vossmann... about 10 years 3 months ago
in my case this does not help. Just to make it a little more clear, sfter Starting CNA 5.1 i only see a small Window with "Cisco Network Assistant" in it, and then nothing happens ! Normnaly i then see things like "loading class xxxx" any Ideas ?
Reiner
Overall Rating: 3.5 (2 ratings)
reiner.vossmann... Mon, 03/12/2007 - 23:41
i have similar Problems running 4.1 everything is fine -> uninstalled 4.1 and installed 5.1 -> installation is O.K. but Application does not start ! No Error Message. Does anyone have an Idea how to troubleshoot / Trace the Start of the App. Problem in my case is on W2k3 Sp1. I have also installed on XP where everything is O.K.
Can anybody give me a little wiev into the secrets of JAVA ?
Reiner
MUHAMMAD SHAHEEN Tue, 03/13/2007 - 16:09
  • Silver, 250 points or more
I guess you have installed NA 5.1 on a machine which has I.E 7.0. If you install NA 5.1 on WinXP or Win2K3 which has I.E 6.0 then it works fine.
Shaheen
oricacomms Tue, 03/13/2007 - 16:33
Hi Shaheen,
actually using ie 6.0.2900.2180_SP2 on XP
I am guessing that its a java handler calling a reference thats not there..
oricacomms Tue, 03/13/2007 - 16:47
OK Found the fix.
after a standard install in the default directory.
in dir "C:\Program Files\Cisco Systems\Cisco Network Assistant\startup" find file "startup.properties"
Edit in txt editor.
Third line in my case: JVM_MAXIMUM_HEAP=1024m
I changed this to JVM_MAXIMUM_HEAP=768m
(I have 2G of Ram)
All good!!!
Correct Answer
reiner.vossmann... Wed, 03/14/2007 - 00:31
Reiner
redrobish Mon, 05/07/2007 - 21:30
In my case, the installation cannot continue...it got an error "the installer cannot run on graphical mode, try running with the -console or -silent flag".
mine is Winxp - sp2
can anyone help?
thanks
