CSS - SSL Stickiness
Mar 12th, 2007
Gilles,
Could you please advice the CSS content configured with stickiness SSL ID and balance method round robin is recommended configuration or not.Are there are any issues with SSL stickiness with the browsers i.e IE .
Note:- I am not using SSL Module in the CSS.
Thanks in advance...
Syed Iftekhar Ahmed Tue, 03/13/2007 - 01:23
  • Blue, 1500 points or more
There are two issues
Some versions of IE (5.0, 5.5 --check http://support.microsoft.com/directory/article.asp?ID=KB;EN-US;Q265369) will
cause the client to change its SSL ID every 2 minutes and this will break
stickyness with application ssl and advanced balance SSL as this is layer 5
stickyness based on SSL session ID. A sniffer trace from the client will
show the ID field change.
You have to be aware that SSL stickiness will only work with SSL v3,
because it comes with the session ID not encrypted. SSL v2 comes with the session ID encrypted and you can't do stickyness
based on that version.So your appliaction servers must be using SSL v3, if you want to use SSL ID based stickiness.
Hope it helps
Syed Iftekhar Ahmed
