ATA 186
Mar 12th, 2007
Dear All,
I have 2 ATA 186, at present they are communicating on Port 1. If I want to have communication on Port 1 and Port 2 simultaneously, is there a way that both port runs on G729 simultaneously.
Rgds,
Jitesh
jgolia Tue, 03/13/2007 - 14:21
Jitesh,
The ATA will either allow G.729 on Phone one _OR_ Phone two. This setting is governed by Bit 21 of ConnectMode.
See the paste below from the following URL:
http://www.cisco.com/en/US/products/hw/gatecont/ps514/products_administration_guide_chapter09186a00800c4d1f.html#42433
~~~BEGIN PASTE~~~
ConnectMode
Description
This parameter is a 32-bit bitmap to control the connection mode of the selected call signalling protocol. Table 5-2 provides bit definitions for this parameter.
Default
0x90000400
21
0?Enable G729 on the Phone 1 FXS port.
1?Enable G729 on the Phone 2 FXS port.
~~~END PASTE~~~
Bit 21 is 0 by default.
To enable G729 on Phone 2 instead use 0x90100400 here.
In my testing I was able to register both ports in a DP which specified a G711 region. I was able to call successfully to other phones then.
When Phone 2 is set in a 729 DP & Region, I am unable to call out. Reorder is provided after another DN is dialled.
Even setting the above ConnectMode value, returning Phone 1 to 711, Phone 2 as 729, I am still unable to dial other DNs. 711 on Phone 2 works fine.
Please rate helpful posts.
Thanks.
jitesh1982 Wed, 03/21/2007 - 22:07
Dear jgolia ,
Thanks for reply,but I have tried all the guidence provided by u before posting query.
Rgds,
Jitesh
apmorgan Wed, 03/28/2007 - 09:30
>>To enable G729 on Phone 2 instead use >>0x90100400 here.
I think this should be:
0x90200400
