How to force DynDNS update
Mar 12th, 2007
How do you force a DynDNS update on a cisco router without dropping the connection?
Is there a clear command I can use from CLI? Using a Cisco 877W ADSL Router.
Overall Rating: 2 (1 ratings)
bradlesliect Tue, 03/13/2007 - 00:15
Thanks for link but it doesn't solve my problem. I need to refresh DynDNS on the router without having to drop the client's line.
bellocarico Tue, 03/13/2007 - 02:21
You may don't like this answer, but I personally think it's easier to manage the dyndns updates installing a client on one of the host pc.
On the client software, the default detection in web (web page) which make this compatible with nat.
bradlesliect Thu, 03/15/2007 - 23:49
how would i edit this to include time intervals?
HTTP
add http://@members.dyndns.org/nic/update?system=dyndns&hostname=&myip=
remove http://@members.dyndns.org/nic/update?system=dyndns&hostname=&myip=
