WCCP with HTTPS
Mar 12th, 2007
I'm trying to configure WCCP between Cisco Cat4507 & bluecoat , it is working fine for HTTP but not for HTTPS . The following is my configuration
BlueCoat :
wccp enable
wccp version 2
service-group web-cache
forwarding-type L2
assignment-type mask
mask-scheme destination-ip
interface 0:0
home-router X.X.X.X
end
Cat4507 :
ip wccp web-cache
interface Vlan18
ip address X.X.X.X X.X.X.X
ip helper-address X.X.X.X
ip wccp web-cache group-listen
no ip route-cache cefend
interface Vlan51
ip wccp web-cache redirect in
no ip route-cacheend
Is it related to the service-group ?
Syed Iftekhar Ahmed Mon, 03/12/2007 - 23:52
You need to enable Https cache service (service 70).This service permits WCCP Version 2 enabled devices to redirect HTTPS traffic to CEs.
(config)# ip wccp 70 <-- To turn on service 70
(config)# int
(config-if)# ip wccp 70 redirect {in|out}
katab Tue, 03/13/2007 - 03:20
Iftekhar,
Thanks for your replay .
Do I need to use the following command
* ip wccp 70 group-listen under the interface link to the BlueCoat , if yes
How can i enable several service group in bluecoat ?
Syed Iftekhar Ahmed Tue, 03/13/2007 - 17:04
I am not familiar with bluecoat.Probably you should try forums on their website :).
Just to clear things up
On WCCP capable routers/switches you need to configure different services to redirect different traffic.
For example
(Web = service 0 also called web-cache)
(SSL - Service 70) (DNS Service 53) (Reverse proxy - Service 99) (FTP native - service 60) etc..
"ip wccp web-cache redirect in" commmand in your case is redirecting web traffic to the configured "service-group" (which is by defination cluster of CEs).
"ip wccp web-cahe group-listen" command is used to configure an interface on a WCCP V2 router to enable the reception of IP multicast packets.
Syed Iftekhar Ahmed
