VOIP configuration over mpls link
Mar 13th, 2007
we want to deploy voip for multiple location over the mpls lines we have between the multiple location can any body suggest the feasibility and how to do it and any related document and guidance for that
Manish gaur
mheusinger Tue, 03/13/2007 - 10:40
what do you call a "mpls link"? Do you have an IP interface connecting to a MPLS network implemented by a provider or do you operate a MPLS network yourself?
In any case you might have a look at
1) Enterprise QoS Solution Reference Network Design Guide Version 3.3
http://www.cisco.com/application/pdf/en/us/guest/netsol/ns432/c649/ccmigration_09186a008049b062.pdf
2) Layer 3 MPLS VPN Enterprise Consumer Guide Version 2
http://www.cisco.com/application/pdf/en/us/guest/netsol/ns171/c649/ccmigration_09186a008077b19b.pdf
3) Various design guides for Unified communications
http://www.cisco.com/en/US/netsol/ns656/networking_solutions_design_guidances_list.html#anchor10
Hope this helps!
Regards, Martin
mheusinger Wed, 03/14/2007 - 08:55
Yes of course, if you route it over the same links. This is why I pointed you to the design guides, which will tell you how to prioritize voip over data to avoid quality issues.
Regards, Martin
manish.gaur Thu, 03/15/2007 - 07:05
hi mheusinger
Thanks for Your comments actually in our scenrio we are integerating our local PBX system with MPls router using E-1 between router(MPLS) and PBX and the vo-ip and pots configured on the same router and i am looking for this feasibility wether we can use the same interfaces to configure the pots and voip which are configured with the mpls connectivity.
Manish gaur
manish.gaur Thu, 03/15/2007 - 07:11
hi
IS their any feasibilty to create voip on the MPLS interfaces.
or i ahve to go for the scenerio liek back to back connectivity between the mpls router and another new router with serial termination and than E1 witht he PBX with new router.
Kindly suggest me or ic an create voip on the same interfaces on which the mpls is coming
Thanks & Regards
Manish Gaur
