spremkumar Tue, 03/13/2007 - 01:45
  • Red, 2250 points or more
hi
can you try configuring boot system flash:iocode.bin (ioscode.bin available ios file in your flash) ?
regds
ipothos1976 Tue, 03/13/2007 - 01:48
in the ,#boot, level when i type "boot", router boots normally...but when i am trying to reboot it i have the same result, i mean router boots in TinyRom again.
spremkumar Tue, 03/13/2007 - 01:52
Once you issue boot statement on the #boot prompt and get onto your normal router prompt try configuring the command which i have mentioned in my earlier post.
After that save the config and do a reload it should boot properly.
regds
